Brief Description: Worked on the O/B pilots side flaperon skeleton
Started to assemble the flaperon skeleton for the outboard half on the pilots side. Got everything clecoed together and clamped on the bracket L-angles and drilled them out. Any holes that needed expansion (spar to rib holes) were drilled out.
