Installed fine fuel filter today. Installed banjo fittings on each end of filter. Cut metal strips to shape for the support clamps, drilled holes and installed filter on the engine mount using adel clamps. Bolts were torqued and indicater glue was installed. Installed hose from fuel pumps and hose from filter to engine. Fuel pressure sensor was installed on the filter as well.
