Brief Description: Attach doublers and skins to top and bottom of the
Manual 10.28 to 10.31
Pic 1. View from above and in front of the leading spar. The two aux fuel lines are clearly visible here.
Pic. 2 shows the top skins being attached. The ice pick (awl) is very useful in lining up the multiple holes through the skin, doubler and rib.
Pic,3 Cleco wars. It took some time to nudge the leading edge section of the top skins into proper alignment. The ice pick was very useful but I still had to remove and replace many cleco's before the skins aligned properly.
