Richard's Web Site
Date:  10-26-2015
Brief Description:  Attach elevator trim tab and trailing edge.
Once the elevator is painted I may not be able to find the attachment holes for the trim tab so I temporarily attached the elevator trim tab and used an ice pick to locate the other attachment holes.
Pic 2. The dark green area in the center of the elevator is the location of the trim tab motor. After the elevator is painted I will cut away this area so I can fasten the trim tab motor. The area for the elevator push rods will be cut out at the same time.
Locate attachment holes for trim tab
Trim tab
Trim tab
Elevator
Elevator
