Brief Description: Mount Motor and assemble Trim Push Rods
Pic. 1 Assembled Trim Push Rods EL-019 per pg 6-24. Did not have correct torque size for AN365-1032 nut so will torque later.
This pic also shows the the assembled Push Rods would not fit into the manufactured slot in the Push Rod Sheet EL-009. See Pic 2
Pic 3 Groove in Push Rod Sheet only 1/2 inch wide and needs to be 1 1/8 inches wide. Sent picture to Lockwood and hoped they had not ordered 100 of those parts El-009. Lockwood did not know where this part came from but sent a new part which arrived 3 days later. Very pleased with their response.
I spend most of the time here trying to re-engineer a new Push Rod Sheet but decided to send pics to Lockwood. This worked well.
