Brief Description: Aileron construction continued.
Install ribs to front and rear spar. Primed using a self-etching primer. This is a bit of an experiment and after it cures I will determine if the primer adhesion is sufficient for the fabric glues. If there is improper adhesion I will respray with a two part primer.
Check level platform and adjust using wooden shims.
