This has become a - install, mark, remove, tweak, repeat project. It's been in about 20 times already, but it's very close now. But putting it in this way, I was able to also position the seat bottom supports Center console still has more work to be done to it before final bond. I need to add the throttle cable, mixture, prop, etc. and sand and fill some low spots. Then it will be primed and painted prior to final assembly
