Lancair Legacy FG-6
Date: 11-12-2005
Number of Hours: 6.00
Brief Description: Inside Main Fuel lines
Wow, what I thought would be a quick project, isn't turning out to be such. These are 2 of the 6 main fuel lines... (they are temped in, hence what looks like different bends in the middle. I still have 5 returns to do as well. It's amazing how long it takes to measure, bend, measure, bend, etc. ... Oh and if you forget to put the ferrel on when there is a 90 degree bend, doesn't mater that you can get the nut on, the ferrel aint gonna make that bend, so you have to start over :( I did that once, and measured from 1 instead of the end of the tape and forgot to add the inch back... That line went in the scrap heap too :( Just when I thought I had these done, I found that I had a conflict with the aileron control tube. I found that the angle of the outboard load pad put an angle on the fuel bulkhead and that angle, even tho I straightened it was too high and caused the tube to interfer with the action of the control sticks. So I had to take that apart and fix it too....Ah well, live and learn
