9 initial anchor nuts were mounted for securing the structure and electric light module. The interior of the light area was painted white to reflect better. A washer between the light module and the rib on each of the three bolts provided space for the zip ties to be inserted behind the module and secure the wiring. Now I will cut and install the clear lens.
Similar to the installation on the other wing.
I will adjust the tilt after I install the light.
You could do the entire install without removing the wingtip through this wingtip opening.
