Brief Description: EMS and Manifold Pressure Devices
I used a vertical angle strengthener to mount the Dynon EMS Module. That angle also supports the VPX mounting structure so its double duty. I realized I need to change the mounting hardware to button head 10/32 because the bolt heads are too close to the EMS module for a wrench. Dynon manual points that out. The Manifold pressure module is mounted on the pilot side near the bulkhead fitting. I tried a piece of plastic tubing to see how it will flow. Its good and I will see what permanent type of tubing is required plus some hose clamps. Also primed, painted, and riveted the VPX mounting structure so that area is rock solid now.
EMS module waiting for button head machine screws. Its attached to a vertical angle for more support.
Manifold pressure module and temp hose attached to bulkhead fitting.
Some of the VPX support structure painted and riveted.
