Turned the fuel tank over and took pictures of the business end for the records. Also noticed one pop rivet I forgot to proseal over so I mixed up tiny bit and did the job. I also can see where I will have to clean off a few minor spots where the proseal will interfere with the main spar when I mount the tank. Those 36 wood blocks worked very well to keep the baffle and tank skin tight together. I am also very happy with the Tank Dimple Die set. The slightly deeper dimple worked perfectly with the small amount of proseal under the rivet heads.
