LUCAS'S WEB SITE
Date:  1-19-2020
Number of Hours:  5.00
Manual Reference:  6-2
Brief Description:  Front spar
Bent the outboard ends of HS-810 and HS-814.
Created the relieve holes in the front spar and bent it. Dimpeld the 4 center holes of the spar and countersunk the matching holes on HS-810 and HS-814.
Made the HS-00006 rib fit around HS-810 and HS-814.
Prepared the HS-00005, HS-00006, HS-706, HS-707 and HS-708 ribs.
Drilled the holes in the aft flange of HS-00006.
