I built 2 tables prior to the empennage kit arriving. I basically used the plans for the EAA Chapter 1000 standardized work tables. It's a very basic and sturdy design, and easily modified to suit your needs. The first table was the standard 2' x 5' size, the only difference being the table top. Instead of using 3/4" plywood, I used 1/2" plywood with a 1/2" MDF top. The Medium Density Fiberboard is great material for a metal working table. The MDF top also was larger than the plywood top creating a 1" lip on 3 sides for clamping purposes. I modified the second table to a 3'x4' size to accomodate the c-frame dimpling table plans that came with my Cleaveland Aircraft Tool C-Frame tool. It quickly converts from a nice worktable with an inset back riveting plate to a nice level platform for the C-frame tool. The removable top has adjuster feet that are locked to level and sit in recessed pads routed out on the table top. When not in use, the C-frame top hangs on the wall. Works well!! If I had it to do over again, I would have made the first table 2.5' x 6', I would have fit well in my available shop space and the extra table top space would be nice. As it is, I'm thinking about building a twin brother to the first table, then I could clamp them together when I need more work space. Not sure my tight area could handle another table though....got to leave room for the wife's van....must keep her happy!
The standard EAA Chapter 1000 worktable with modified top...plans available on the internet...
The 3x4 table with inset back riveting plate. Note the recessed pads in the corners.
The 3x4 table with C-frame table on it. This is a really nice setup from Cleaveland Tools.
