-Machine countersunk the nutplate rivet attach holes on the top plate of the center section assembly.
-Unclekoed the two sections and wrested the bolts and spacers out (close tolerance bolts
-Deburred the previously drill holes.
-Primed the spots on the anodized parts where I did machine countersinking
-Reassembled the sections, except this time I included the center bolts that hold the fwd control mount fabricated earlier and the seat belt attach lugs.
-Riveted them together, and installed the snap bushings
-Done with center section for now.
Riveted together, you can see the seat belt attach lug sticking out the top plate.
Center section temp installed. Looking good!!!
A view from the inside, you can see the fwd control mount in the upper middle
