-Stopped at the storage trailer on the way home from church and grabbed the horizontal and vertical stabs out of storage. -Separated the F810 and F885 spacers and edge deburred them -Repositioned the fuse and tables to make some room….the wife needs to have her spring garage sale soon to get rid of all the stuff that’s piled up… -Leveled the fuse side to side and front to back -Clamped the rear spar of the horizontal stab to the stab attach bars, put the F-810 spacers under the outboard ends of the Splice angle on the front spar. -In order to set the right incidence the plans tell you to insert a 3/16” drill bit between the rear spar and aft deck.
