Brief Description: Adding Tailcone to FWD Fuselage #2
-Edge deburred the cockpit rails and the center section bulkhead caps on the 3M wheel and then with a file. -Cleco'd the bulkhead caps and the cockpit rails in place per the plans. -Adjusted the upper longerons so the reference mark used to bend them was lined up with a slot that was manufactured into the cockpit rails - looks good! -Cleco'd the Upper and Lower Longeron gussets in the Center FWD Section -Clamped the Upper Longerons to the webs of the engine mount bracket on the backside of the firewall -Clamped down the upper longerons
Bulkhead caps in place
Cockpit rail has 6 cleco's in it holding it on to set the position of the longeron
