Brief Description: Mid Fuse Structure #5 & Joining Fwd and Mid Fuse A
Lots of visual progress today! -Cleckoed all the arm rests and bulkheads to the inside of the mid fuse skins -Final drill all the holes associated with putting those parts from the previous step together. -Then it got fun when it was time to Cleko the mid fuse assembly to the forward fuse assembly...there's a fuselage taking form on my bench! -Deburred the edges and openings of the forward fuselage L&R skins. -Clekoed on the forward fuselage skins and associated stiffeners. -Ran out of 1/8" clekos...will need to buy some more...
You can see the armrests and bulkheads installed on the inside of the left mid fuse skin
Mid and fwd fuse assemblies are connected
View from the rear...time to assemble the aft fuselage...
