Brief Description: Rt Wing #16 - Prepping top outboard skin
Started by removing the blue plastic from the top outboard skin. Deburred all the holes. Edge deburred the skin. Rolled the edges that needed it. Dimpled all the holes with the c-frame dimpler. It's amazing how much cleaner a job it does versus using a squeezer around the edges - alot less warping. Scarfed the area where the 2 skins overlap so they lay down nice behind the tank skin. Primed all the rivet lines. Ready to start riveting the top skins.
