Brief Description: Right Wing #6 - Drilled leading edge skin/ribs
Marked, set, and drilled the joint plate that goes between the leading edge and wing tank. Drilled all the holes in the leading edge, except for the rib rear flanges through the spar (will do tomorrow). It was time to start clekoing the tank together, and that's when I realized I still had 7 tank ribs to straighten and flute....yaaayyy...so I set about doing that and was happy to get done until I realized I was supposed to edge debur them first. Oh well, it's not a big deal, more of a minor inconvenience to debur around flutes. Called it a night...will debur later....
Joint plate drilling. The Tank skin will fit over this.
