Brief Description: Right Wing #5 - Skins and Leading edge
Drilled all the wing skins. Removed the lower outboard skin and put it away for now. Cleko'd the leading edge assembly together and then cleko'd that to the wing. Furge showed up just in time to hold the inboard rib of the leading edge in place. This rib comes with no holes and you must drill up through the spar in the rear flange of the rib.
