Brief Description: Left Wing #25 - Dimpled bottom skins
Dimpled the bottom wing skins. Removed the fuel tank. Have everything set out to prep for the final priming session of the left wing. I need to prime both aileron mount brackets, the aileron gap seal, the flap brace, the rivet lines on the skins, and I'm going to tape off and prime the outside of fuel tank (not the skin, just the rear baffle, end ribs, and z-brackets). Not sure when I'll get my next multi-hour opportunity to accomplish that.....
