Brief Description: Left Wing #22 - Prepping bottom skins
Finished removing the plastic from the lower inboard wing skin with a soldering iron. Deburred all the holes. Edge deburred the entire skin. Edge formed those edges that require it. Started removing the plastic from the inside of the lower outboard skin. I'll remove the plastic on the outside rivet lines tomorrow.
Tip: Use a piece of PVC to "roll" the plastic onto...works great!
