Primed the exterior of the large aileron pushrod tubes. Since AFS says you can, I decided to brush it on instead of shooting it. It's not nearly as nice looking, but just as effective, and a whole lot easier to clean up.
I also took the two top wing skins and walkway doubler off the wing and primed the enitre doubler and all the rivet lines on the inside of the skins. That way there is primer/sealer on all contacting surfaces. I tacked the skins back onto the skelton with some clekos. I'll cleko it all on later and start the wing skin riveting.
