Brief Description: The start of about 3 houurs cleaning
I have found that the primer prep takes me about 12 minutes per rib. There are 14 main ribs in the wing. I am looking at 3 hours of work with maroom buffing pads. I will use a die grinder with a buffing wheel. I use a mouse type finish sander with a maroon pad. I will also use lots of hand work. While I work I am double checking my earlier edge deburing work to make certain I was through.
