Plan is to make a frame that I can use to lay up a fiberglass golf club sleeve. The sleeve will extend from the aft edge of the baggage floor into the mid section of the fulelage. The sleeve needs to be below the seat belt cable, above the elevator push rod, and allow room for the static ports and their plumbing to rest along the outside wall of the fuselage.
