Tims Lightning XS
Date:  4-13-2017
Number of Hours:  1.25
Manual Reference:  1.7
Brief Description:  Cut Wing Spar Opening
Pretty scary cutting all of these holes in the fuselage this early in the build. I'd be more comfortable bolting something on rather than cutting something out.
I do know that a square corner could lead to stress cracking, so the corners of holes should be rounded. To do that, I drilled the corners and then connected the dots using the body saw. There is less dust with the body saw that with a dremmel disk, but the line is not nearly as straight. So, a bit more sanding is necessary,
I must have measured that hole a hundred times before cutting. LOL!
Here's the hole after the spar box was installed
Another glamour shot
Whew!
Whew!
