OK, so this pan is not symetrical. Maybe I should ad a shim under one side. When I did so, the pan was no where close to sitting on the rails. Aargh!!!
Since the center of the fuselage is a bit deeper that the outside edges, I'll swap seat pans and make more relief cuts. We'll just call that other huge hole a lightening hole.
