Tims Lightning XS
Lightning XS
Body Work
9-30-2017
Body Work
Sand Leading Edge (LE) of wings.
Sand trailing edge (TE) of wings to scribe line for flap and up aileron travel. Bevel TE for more clearance.
Add Light Weight Body Filler (LWBF) to HS/VS joint, right wing/root joint, wing LEs and HS LEs.
Fiberglass left wing root intersection to form fairing.
Tape fuselage so filler doesn't stick
Fiberglass Left wing Root
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
