Flipped plane over to body work the belly. Did this by standing plane on its nose, rotating 180 degrees and lowering tail onto sawhorse.
Removed 1/4" of lower HS TE for better down elevator clearance.
Removed FG tip plugs from mold. My paper must not have had enough wax, because the FG did stick to the paper. Glad I used 2 layers of paper between the two layups.
