Mounted wheel to gear leg. The castle nut below is used to set tension on the wheel. It should take at least 10 lbs of force to turn the wheel to the side. Less than that and it may shimmy during taxiing. I'll figure out how to measure that later.
First, level plane then set perpendicular to the floor.
