Brief Description: Moved left brake bulkhead fitting
The old brake line hole can be seen on the left center of the fairing in Photo 1. This location prevented the aft half of the fairing from being forward enough to fit closely around the gear pant. To resolve this, I relocated the brake line entry in to the fuselage through the spar box. The box is high enough for the washer and nut to fit under the box. I had a thin wrench to hold the nut while I tightened the brake bulkhead. Now, the pant and fairing fit perfectly. I'll do the right side tomorrow.
Too far aft for fairing to fit.
Old hole location left, new location through the spar box.
