Brief Description: Wheel and Brake installation cont.
Attempted brake line install. Because of the changes to the spar box, I had a question about where the fitting should be installed on the belly of the fuselage. If behind the spar box (per manual), then the leg/fuselage fairing will need to be pretty long. I don't have the fairing yet, so can't just look at it. Builder sites have the opening in different places. I'm guessing this is because of the different spar boxes.
If installed behind the spar box, my stainless steel brake line is not long enough to wrap around the gear leg as per the plan, but it is long enough to be secured behind the leg.
After checking with Nick, he said the fairings are large enough to conceal the fitting when installed behind the spar box. So, a couple of days later, that's what I did. Pictures then.
