Tims Lightning XS
Lightning XS
Right Wing Taxi Light -1
The taxi light should be centered in the lens pocket, so I made a template to locate the four corners. I match drilled through the template and used the dremmel to connect the dots. I then installed nut plates and trial fit the light.
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
