Tims Lightning XS
Lightning XS
Aileron push/Pull Rod - 1
The first step to fabricate the aileron pushrod is to install a cone and bearing on one end. A little grease helps the cone slip on with the help of a rubber hammer.
Temp bolted to the bellcrank.
Lightning XS Home
1921
465
Body Work
120
274
Cockpit
53
103
Elevator
219
Gear, Wheels, Brakes
57
Kit
Panel
229
