Tims Lightning XS
Date: 2-1-2018
Number of Hours: 5.00
Brief Description: Avionics Planning
Finished the Vertical Power Manual and labled the pins on the d-sub and 25 pin connectors to make things easier when I start building the wiring harness.
The picture is not very good. I used Wite-Out to identify the number pin on each corner. For those of you keeping score at home, Male pins and female pins are numbered backwards. When installing pins in the male pin, pin # 1 is upper right corner. on female pins, the #1 pin is top left. Better to mark now than to wire one of these connectors backwards. Smoke is great for BBQ, but bad for avionics.
Before starting the harness, I'll need to know where everything is going to live. I still need to decide on battery, remote communication radio, transponder, ADS-B Receiver, both ADAHRS units, the EMS module, and Vertical Power unit placement. Time to stop studying and make some mounting brackets.
