Brief Description: Fuel pumps and ECU installation
Mounted the fuel pumps and filters onto bracket and then installed on firewall with stand-offs to clear the angle bracket. Did some modifications to the battery box to keep the battery from moving. Needed to put a 2 inch hole in the firewall for the ECU plug to go into the Avionics compartment. Will have to make a reducer plate that goes around the wires and seal it to keep fumes from entering the plane. Mounted the ECU about an inch and a half above the cooling fan on stand-offs between the map box and radio. You can see the two caps that are now protecting where the wires from the engine and wires that go to the panel will be attached.
