This is a combination of many hours over the last week or two. Not much happening to show so this is it. Working on the fiber glass forward part of the canopy where you put filler on, sand it off and repeat many times. Feels like you are getting no where but I think I am almost done. Putting on spot putty to fill in any rough spots and small pin holes to get a smooth finish. Once I am happy I will trace the finish countour with the template I have made, remove the canopy and cut and sand to the line. Since there isn't much in the way of changes I have only taken 2 photos to show. Once the canopy is off the plane and trimmed it will be easier to see and from 3000 feet it will look perfect. Then I can start on the engine installation.
