ELT ( Emergency Locator Transmitter ) is mounted and working on soldering the wires from the panel to the jack plug. Put the bracket and antenna in place and hooked up the wires. Bundle and tie wrap the wires to the ELT case ( orange part in picture) Yellow lever is the pin handle that holds on the wings . One each side of cockpit. In picture 2 you can also see single wire going to the sending unit on the tank.
