Put partial bulkhead panel into place behind the fuel tank. I split the bulkhead so I can remove the other 3/4 of it for inspection on the tail cone section without having to remove the tank everytime. You can see it sticking out from the side and top of the tank in picture 2. Installed fuel tank into position and hooked up fuel lines from the bottom. Put special bolts in and torqued to proper amount.
