Paint Booth I had made a frame work for a paint booth many months ago while waiting for parts to be delivered and now I finally get to put it together. It is made of 1 1/2 inch pvc pipe and is 10 ft wide and about 8ft high. The length can be anywhere from 5th to 20 ft depending on how many sections you put together. When done it can be taken apart and stored again and the only thing you have to replace is the plastic. It should keep the dust out and provide clean air through the filters. I also have a paint system that will provide fresh air to the face mask and a hood so you will not be exposed to any harmful fumes.
I hope to have a few pictures in the next couple of days of everything working and some decent painting on the parts.
