Add fittings to brake assemblys and mount with the tires into position. Make up the caliper brake lines and fittings and install into position. Secure brake line to the F-1204D center section aft bulkhead with wire ties. Bleed all brake lines and check for leaks. Right wheel fitting had to be turned one turn to fix a small leak. Looks good now.
