Finished the wiring for the spar pin safety switch. Ran the wires for the fuel level wire WH-Q428,GPS Data out wire WH-F395 and ELT power WH-P325. Ran all of the other wire through bushing to the tailcone area. Did not run the red fuel pump wire because the fuel pump will be located in the engine area.
