Did not put the Fuel Flow wires for the Transducer through the panel base because the transducer will be installed in the engine compartment because of a different engine. Installed and connected the wires for the WH-00056 Aux Music Jack Connected stall warning wire. Ran wires for the Auto Pilot and put on ES-00010 Molex Plug. Ran wires for the spar pin safety switches. Could not get the switch to activate properly so had to make a modification and change the location of the switch mount. Now it works properly every time.
