Sanded the first coat of epoxy applied to fill pin holes on exterior of the doors. After blowing off and wiping down with a sticky cheese cloth, I mixed and applied another epoxy coat. I plan to sand it off tomorrow. Next I installed all the panels. When the cabin was installed, epoxy and glass fibers were placed in all radius and squeezed out when bolted down. Now, the remaining 1/8" radius will be filled with epoxy/micro and then painted. I then cleaned off and straightened all the Lord Adhesive radius around both aft windows. This will make installing the aft ceiling cover easier.
