Finished sanded the exterior of both doors and then rough sanded the inside of the door. I covered one door with an epoxy mix cut with 50% acetone. It was recommended that it would fill the pin holes just as well as straight epoxy, with less sanding. Next, both door radius were sanded. The panels that butt up against end were protected with shipping and mold release. After wetting out the radius, an epoxy/micro mix was added. When it cures, this will be sanded and painted.
