9-11..sad day. I rough sanded the left forward window and semi finish sanded the right side. (Semi means still using #80 grit, but getting closer to where it should be. I also semi finished the forward edge of the left door. As it was sanded, I noted that on this side, thee jamb as 1/16" lower then the door so I ended the day by adding 1/8" epoxy/micro layer.
