I used a Dremel sanding attachment I leveled the glass where the windscreen clips left humps. After sanding, vacuuming and wiping with acetone, I applied one 1", one 1 1/2" layers where needed to bring it up near to the perfect radius. After rolling to remove bubbles I wet out the right side top piece in plastic and the fairing where it was to be placed. After placing it, I rolled and applied peal ply. The left side was then wet out, cut to the template and placed, followed by peal ply. Will let this cure for a couple days.
