Drilled out the temporary threaded holes and installed nut plates on the fairing brackets. Then I drilled and installed the nut plates on the forward edge that secures the front fairing cap. All was assembled, the wheel reinstalled and tested for fit. Fit great. Then all was disassembled and the epoxy around the brackets was sanded and touched up filling any low areas and adding filets where needed. I will let that cure overnight and then finish sand.
