More wheel fairing work today. I put a finish coat of epoxy/flox/glass beads around the pads that were created a few days ago. Then I set the side 1/4" washer again. I had placed them earlier, but they set up at the wrong angle because I tightened them before they epoxy set. It only took a few minutes to cut away the old epoxy/flox mix and reset. I also added the 8 but plates on the wheel brackets. The washers ended up perfectly parallel to the wheel extension.
