I routed a red pitot line under the floor that will "T" into the pitot pressure line at the left wing root. That way I will have pitot pressure behind the bulkhead for my sensors as well as under the dash. I really did not want to run it inside the conduit because I do not know how much wire I will need to pull through. I also added a red tube on both sides which will guide my RG400 coax to COMM1 and COMM2 antenna. This way, I don't have to wire them yet. I finished running the #2 starter wire on the left side. To recall....the bushing hole is 1/2 inch and the lug barrel is 9/16. I don't want to drill it bigger and thought about using two bushings. Decided on just cutting off their lug, running the wire through the hole, and installing a new lug. I will do that at a later date. With the floor clecoed in place, I plan to revit them both down tomorrow.
